June 22, 2024, 05:35:55 PM
182 Guests, 0 Users
  • Online today: 283
Guests: 182
Total: 182
How to hide my yoke
Started by FSAddon_boss, November 14, 2021, 11:30:48 AM
FSAddon_boss
I suck at thinking up proper titles for threads, sorry. Just wanted to pick your brains here..... my problem being that I am not sure how to make my yoke stick out from the panel on the proper height.
The problem is that the panel is made of 8 mm plywood WITH a monitor stuck BEHIND it..... and the housing f the CH Eclipse yoke is preventing the monitor to be lowered to the level of the yoke axis.
Moving the panel/monitor further forward will limit the movement of the yoke....
Anybody know if it is possible to disassemble the plastic housing and cut off the top/forward part of it, so the monitor can fit in lower?
Any other ideas??
Francois
Francois A. 'Navman' Dumas
retired
Like many things that prevent us from getting the proper look and feel. We need to explore.  Carefully open up your yoke, and I am sure you will see there is a lot of useless plastic in the way.
The real test is when you buy brand new monitors and immediately pull all the plastics and bezels off them, voiding the warranty and your wife watching you and asking what are you doing.
Just be careful, you can always put it back together.
I've seen folks cut the yoke tube and add an extension of some sort. THere will be wires in that tube so you'll need to be careful if you go that route.
If you do, it should be a simple matter of adding wiring to reconnect everything.
FSAddon_boss
Good thoughts...... will try and see what's inside......
Francois
retired
FSAddon_boss
Quote from: Trevor Hale on November 15, 2021, 05:05:19 AMThe real test is when you buy brand new monitors and immediately pull all the plastics and bezels off them, voiding the warranty and your wife watching you and asking what are you doing.
Googling how to remove  a bezel from a monitor...... now you did it !!!
Francois
retired
FSAddon_boss
I found this video (and website) that shows me how to disassemble the CH yoke.
Making the shaft longer seems like a difficult job (to me), but am thinking that I can saw off part of the upper housing to accommodate for the monitor and panel....
https://youtu.be/TmKrffu4QlU
Francois
retired
Quote from: FSAddon_boss on November 16, 2021, 12:33:43 AMI can saw off part of the upper housing to accommodate
Spoken like a true sim builder!
FSAddon_boss
Quote from: RayS on November 17, 2021, 02:53:30 PM
Hahaha ! Thanks Ray.
Well, I bit the bullet and decided to have a go at extending the yoke shaft........ Found a video that showed me how to open the CH Products yoke unit, and what was inside...... since I have TWO of the units lying around here, I figured I could try it and possibly ruin one, and still have the other.
Turns out I didn't need the spare one. I cut off the shaft, inserted a bit of metal tube and extended it just enough so I can mount the panel in front of it. Had to extend the internal (tiny!) wires too..... and while at it, I replaced the original springs with bits of rubber band, to make the yoke move lighter.
Going to TEST it today.......   :o  :o  :o  :o  :o
Francois
retired
FSAddon_boss
Update: it all works fine !! PHEW !!!!!
I extended the shaft so the yoke sticks out of the panel while hiding the casing behind it.
I also replaced the very stiff springs by rubber bands .... easier to control now, although they could be a bit stiffer I guess.... experimenting.
Francois
retired
Try different springs
Rubber bands get weaker after a while.
FSAddon_boss
Quote from: jackpilot on November 21, 2021, 07:35:23 AMTry different springs
True, but not easy to find springs around here...... will keep it in mind (and will try to design the cockpit so that I can take it apart easily in order to change parts).
Francois
retired
