June 26, 2024, 12:24:15 AM
94 Guests, 0 Users
  • Online today: 107
Guests: 94
Total: 94
Interfacing to MSFS...
Started by RayS, August 18, 2020, 09:56:48 PM
I figure it may take about 6 months to a year to convert all my Teensy Microcontrollers over to MSFS from X-Plane.
I currently use a CANBUS architecture so I will only need to worry about the following:
All I need is a way to pass data to/from the main CANBUS controller. (In my case it will most likely be a Arduino 256 Mega)
There are several options out there, and Mobiflight looks promising, but it also looks like an end-to-end solution. All I need is to send/receive data to/from the main 256Mega controller. CANBUS will do the rest.
Looking to the group here for inspiration/suggestions....
Given that you know how to program, use FSUIPC or whatever the new interface is with:
https://www.ftdichip.com/Products/Cables/TTL234XSerial.htm
Or one of these if you don't want to use the UART https://www.ftdichip.com/Products/Cables.htm
Or are you looking for a software solution?
Have you tried FS2020 ray? Are you making the switch? :)
Kyle, I will give that a shot.Thanks for the info!
Kurt,
I just installed MSFS2020 tonight and went on a brief dusk flight around the Seattle area.
Verdict: I won't be able to get rid of X-Plane fast enough! Unless Laminar Research starts to really focus on the scenery aspect and seasons and not "Fighting robots on Mars" (A euphemism alluding to nifty prop-wash effects that are maybe 0.005% better), I see no reason to keep it on my hard drive.
Quote from: RayS on August 19, 2020, 10:07:34 PMI see no reason to keep it on my hard drive.
Knew you would see the light one day :)
