June 22, 2024, 03:05:29 AM
276 Guests, 0 Users
  • Online today: 283
Guests: 276
Total: 276
Stab Trim Indicator...
Started by ScottThePilot, July 01, 2019, 11:22:02 PM
ScottThePilot
Hi All,
On our upper EICAS, we display the Stab Trim setting and range (doing some testing) which is currently -1 ... 10 units.  We have a FSC TQ Pro Motorized.
The MCP.INI has these lines for trim...
TrimMin= 0
TrimCtr= 5
TrimMax= 17
                              / 737 Trim Gauge Min/Ctr/Max
And in the FSC section near the bottom after calibrating the trim on TQ from within MCP...
FSCTQTrimOffset0= 64
FSCTQTrimOffset10= 138
In the PMB738.TXT (under the CDU -> Types folder), the following lines appear...
TrimProportional=Off
//green band
TrimMin=2.5
TrimMax=7.0
//scale min and max
TrimScaleMin=-1    ;Not real world numbers - set to these values for proper display.
TrimScaleMax=10   ;Not real world numbers - set to these values for proper display.
This would seem to tell me that these numbers (-1 and 10) defined here are the ones showing up on the EICAS and that they need to be changed to the real numbers.  Our actual TQ indicator...
1. Shows 0 to 17 as the range which matches the MCP.INI file
2. Shows the "Green Band" being 2.5 to 8 which pretty much matches the PMB738.TXT file.
As is obvious when moving the trim, the -1 ... 10 scale doesn't match the 0 ... 17 on the TQ no matter what setting.  So I believe I just need to make the scale on the EICAS match the actual TQ scale (0 ... 17).  I modified the PMB738.TXT file and changed the -1 and 10 to 0 and 17 to match...
//green band
TrimMin=2.5
TrimMax=7.0
//scale min and max
TrimScaleMin=0    ;Not real world numbers - set to these values for proper display.
TrimScaleMax=17 ;Not real world numbers - set to these values for proper display.
But when I fired up the SIM, the EICAS scale was still wrong (-1 ... 10).  Is there a Glass Cockpit INI that needs to change also?  Did I miss something else?
Thanks for any help...
ScottThePilot
Just a quick update...
I exampled the PMB738.TXT that was under the CDU/Types folder.  I looked that the GC folders for Capt, F/O and Upper EICAS and they all have a .TXT file also.  They all have the same -1 to 10 scale as in the one is CDU/Types folder.  I changed the scale to 0 .. 17 in a couple of these and also the main CDU/Types file but the EICAS still shows -1 .. 10 as the scale.
I just don't know what the file to modify to change that scale to match the TQ indicator.  hoping someone can help with this config item as I am at a loss where else to look.
Thats a good question.  I am not sure if it is even possible as that is part of the graphic.
May want to email Enrico about that one.
Support@projectmagenta.com
ScottThePilot
Hey Trevor,
Thanks for taking a look here.  I did email Enrico about how this works and which file to modify.  It is just a number so while it is drawn by the graphics, it should be redrawn just fine just like any engine number as throttles are moved.  I hope that I understood your comment correctly.
After reading the manual some more, The PMB738.TXT file in the CDU/Types folder is the one we should be able to edit (and select in the FMC) and would load the right scale.  I believe the file gets copied to the NETDIR so that all machines can pull from the file.  I just haven't been able to find the right file to edit I guess.
Will let you know...
Also Trevor, can you take a look at my other post on the MCP.INI file and how the command bars operate.  Perhaps you can try it and let me know if my theory is true.
