June 21, 2024, 12:26:57 PM
286 Guests, 0 Users
  • Online today: 283
Guests: 286
Total: 286
Wanted: OEM gear lever 737
Started by kurt-olsson, April 23, 2018, 12:52:29 PM
Let me know if anything pops up.
They do ..at insane prices
Besides the mechanism at the back is HUGE and hard to fit in a regular install :o
how you going to tension it   and power it    curious 😁
Tension is allready there if i am correct, and power the solenoid with 28v.
archen
Try Nick at APHS. He usually have them but at high price.
I've modified a real lever to fit FDS MIP.
Had to change microswitches and mill a few new plates. Also cut it shorter.
See here
https://riksarchen.wordpress.com/2014/02/22/mip-progress-now-fds-mip-instead-of-simworld/
Anders Simparts
http://www.anderssimparts.com
Seen one at APHS but too much for me. Hope to find one with reasonable price range.
BUMP
I am also interested in replicas if its OEM dimensions and look.
The OEM is a huge monster , you would be better off with a nice repro
If I were you, I'd buy one from Nick at APHS. Even though it might seem high priced, it actually isn't when you consider the time and cost to remove parts from the real planes.
And, in the past I thought the same as most, but after removing items myself I can attest that it's not easy to get things out of 30-40yr old aircraft...
Besides, waiting for someone (another builder) to sell one (or whatever you may be looking for) can take a long time, so paying that little extra for items from Nick is well worth the "not" waiting forever to get one from someone else.
peterkwu
I agree with John that the price is actually reasonable when you think about the cost of removal. Having watched the OEM resale market for 10+ years, I can tell you that the cost of these items has gone up dramatically the past few years. Nick is actually one of the most reasonable sellers of OEM parts at this point in terms of cost.
I have to respectfully disagree with Jack that a reproduction model is just as good as an OEM one. In my opinion there is no comparison. I've had several reproductions (FDS, CockpitSonic etc), and they never seem to make the handle long enough to accurately reproduce the movement of the real thing. The OEM model is also really heavy duty, and gives a much more satisfying 'thunk' when moved from one position to another. I don't know of a reproduction model with a working override trigger or solenoid, if someone does please correct me.
The solenoid is super easy to get working. I published a how-to for converting an OEM lever in 2015:
http://www.fly737ng.com/?p=228
As most OEM levers out there are from classic model airframes, you will also probably want to exchange the old, yellowed, large wheel for a new, smaller, white, NG style one purchased from FDS. Here's another post on how to do that:
http://www.fly737ng.com/?p=301
In summary my advice is to save enough $$$ to buy one from Nick at APHS. You won't be sorry.
Peter
Check on my progress at
Exactly what Peter said.
Also if you want to make it completely NG-like, shorten the handle by 1"
OK OK Guys... you almost convinced me!!  :D
rw
#12
Hi guys,
In the same boat here - been lurking for months for a OEM gear lever (assembly) on Ebay and Dutch second hand websites but was unsuccessful.
Until I found a 737NG lever for only 2800 USD ;D here
And a one inch longer another version for 86 USD here here.
I purchased the 86USD one and there seem to be more available.
This is not the whole assembly, so requires additional work to get it functioning. Which will require:
- an axis for rotation
- friction for the rotation
- a backplate for the 3 gear settings (up, down, off)
- a structure to lock handle using solenoid
- a solenoid for gear lock override
- cutting the handle 1 inch short
- adding a smaller (and less yellowish) gear lever knob
Quite some engineering ;)
Upside is that you have full flexibility in fitting it in the MIP. For me this is the main reason, as I will have most freedom picking sizes to most optimal LCD screens for CENTER DU, PFD, ND in terms of resolution, viewing angle and contrast ratio.
Hope this is useful!
jeffreyk
#13
Roel,
I don't believe that's an NG handle you're having over there.
It seems shorter because the spring is fully released.
If you take a look at actual NG levers you'll see that the rivets of the "wheel" part are very close to the red unlock trigger so not as seen on that eBay page.
Might be wrong but to me it's just a very expensive CL handle.
rw
#14
Hi Jeffrey,
Seems you're right. Probably must have been a little dizzy due to the price tag ;)
Quote from: jeffreyk on August 20, 2018, 12:34:51 PM
Roel,
Correct,
This one has been on Ebay for years at the same price  :o :o
The NG levers don't have the cable wheel either, they use a push-pull cable instead of the older cable & drum setup
