June 22, 2024, 06:18:53 PM
299 Guests, 0 Users
  • Online today: 324
Guests: 299
Total: 299
PFD Bezel measurements needed
Started by ifeliciano, March 20, 2018, 08:42:00 PM
ifeliciano
I have the documents from MARKUUPILOT with the overall size of the PFD, ND, bezel, but i'm not finding the specific width of the bezel. I have marked the inserted image with two locations, A & B. Can someone with a OEM 738 MIP assist with measurements?
jeffreyk
Hi there!
Actually it's not an OEM MIP you're after but an OEM DU.
I doubt simmers have those but if one does, I would like to know too for my own future build :)
Perhaps someone from maintenance or a helpful pilot can give some guidance on your question.
Jeffrey
Karl737
Hi guys,
A= 11/32"
B= 3/4"
Karl
Or if you work in mm,
A = 8.7mm
B = 19mm
These are almost exact conversions but many third party MIP frames will be 9 and 19mm
In fact my Engravity MIP is 11mm and 20mm
Actually the bezels and glass on my MIP are real. If you need any other measurements let me know.
ifeliciano
ifeliciano
Forgot to ask, but what does the top of the bezel and the gaps between the bezels measure ?
D=5mm As for the gap, remember that these are slide out units so that is going to be a little different on every set. Mine are right together so I can not help much.
ifeliciano
Quote from: Bob Reed on March 22, 2018, 12:44:26 PM
Thanks Bob.  I just literally became aware the DU's slide out with the bezel attached (reading Flaps 2 Approach site). I'll probably set the gap somewhere between 2mm and 4mm.
Basically no gap, one or two mm max
ifeliciano
Karl737
If you are OCD like me, gap is 1/16th (Boeing use imperial measurements) or 1.6mm.
Karl
