June 25, 2024, 06:31:11 PM
67 Guests, 0 Users
  • Online today: 25
Guests: 67
Total: 67
Resolution issues
Started by ivar hestnes, April 01, 2010, 10:29:29 AM
Hi fellas :)
Equipment as follows:
Win7 64
Nvidia GTX285
Matrox th2go analog
3x Benq MP782-ST (native 1280x800) http://www.benq.com/products/Projector/?product=1609&page=specifications
The th2go analog should be able to do 3840x768 according to http://www.widescreengamingforum.com/wiki/TH2Go_FAQ
But no chance I am able to set my desktop to 3840x768. I can manage to set it to 3840x1024 or 3072x768, but with the result that airplanes will look stretched. They look like they are long and thin. Not ideal for sure.
Anyone have an idea of what I am doing wrong here? Or is it the hardware that cause issues? I borrowd a digital th2go for testing also, but it resultet in nothing but issues, lol.
Anyone else running a setup at 3840x768 or 3840x800 here?
Ivar,  I am not sure but is it possible the problem is a Windows 7 / Triplehead2go issue?  I am not so sure they are 100% compatible but I may be wrong.
I hope you are wrong, but it could definitely be a win7 vs th2go issue.
mpl330
Hi Ivar,
You tried nhancer? Sorted many a problem with nvidia cards...
Hi Mike  :)
Never tried Nhancer. Isnt that just for antialiasing and "visual quality" issues? Or can I set custom resolutions in that application also?
I have tried Powerstrip also today, but still no success.
andarlite
Quote from: ivar hestnes on April 01, 2010, 10:29:29 AM
Hi Ivar
I'm using:
Win XP/64
Digital TH2G
Nvidea GTX275
3 22inch LCD (native 1680x1050)
I normally run at 5040x1050 but I was able to switch over to 3840x768 and 3840x800 and both resolutions ran fine.
I have noticed that the TH2G is smart enough to limit your resolutions to what your monitors (or projectors) can handled. Have you tried with 3 LCD's just to see?
Henry
Level D 767
FSX
Volante
I would think you have checked this, Ivar, but here goes....
Windows sees the TH2G unit as a graphics card, and has to have it's driver installed to allow for the resolutions in question.
The projectors should be set to 16:9 aspect.
Vidar ::)
Yes Vidar, the projectors are set to 16:9, and the th2go driver installed. But still no luck :)  Thanks anyway :)
Henry, you might be right. Maybe the th2go is smart enough to limit the resolutions. Since my beamers is native 1280x800, and maximum th2go analog is 3840x768, that could be the issue. I dont have any LCD?s around to test with, but it is possible that I have to buy the th2go digital to get this working.
I borrowed one to try with, but only got issues, lol. But that could be my fault also ;D
NAX228
Since 768 and 800 are not the native resolution, it could be an issue with the projectors is my thought.
Do they show correct picture when selecting 3840x1024? Maybe they stretch your given resolution to fill up the whole picture?
800 is the native vertical resolution on the projectors, but the analog th2go does not have support for that.
They do show the correct picture in 3840x1024 mode, but the 1024 is compressed vertically, so objects will appear stretched.
If there was something wrong with the projectors, It would be serious bad luck if all three had issues. I doubt that one ;)
I am more and more convinced that I need the digital th2go to get this working as it should.  :)
NAX228
I did'n mean the projectors was "broken" more that they function in a way to automaticly stretch the pic to add up for missing pixels eighter way, up or out.
Well, I only hope you get it running.
Ahh, understand what you mean now :)
I have tried all the screen size options on the beamers also. Didnt help. Running out of options for sure ;)
But we never give up, lol.
Ivar,
I had the same issue with the Benq 772ST's (native res 1024x768) running under WinXP.  I ended up having to download the TH2Go software suite and the Mode Expander Tool and installing them.
Now I have all the resolutions available and am running in 3072x768.
oter32
#13
Hello.
As  far as I can see, Ivar, every side of your Matrox problem is looked upon  above.
Exect one thing:  I can’t find any Software tools for Matrox Analog edition hardware explicit for Windows  7- 64.
I am sure  you are aware of it but for the other of us planning an OS update, it could be useful to know.
Nils
Hi Warren and Nils.
Thanks for your inputs here.
I cant find any win7 specific software either. I think it is not necessary. I can run a 3072x768 format here. But thats a 4:3 format. It seems like I cant run the projectors native widescreen resolution.
Very strange all this.
I have someconfidence in Henry`s post aove. That the th2go is smart enough to limit the resolution to what the monitors can handle. And if so, I need a digital th2go. Since native 1280x800 cant be run on the analog. Analog supports up to 760 vertically.
