June 23, 2024, 12:00:22 PM
170 Guests, 1 User
  • Online today: 155
Guests: 170
Total: 171
Big contract
Started by jackpilot, March 28, 2010, 10:18:02 AM
I need two custom acrylic panels, boeing gray, no engraving, to fill the gap under my TQ levers.
Who will be the lucky one to make  it???
Jack, I would be happy to make for you.   All I have is the white Acrylic though if that works for you.   I have 5.8mm.  It looks like you want to bend around the top?  If that is the case then I think I have just enough 3mm poly left that would work nice.   If is a little more flexable.  The paint I have is a good match and really tough stuff.    Do you need any holes drilled?  It is very easy to plot and drill them precisely on the cnc.
Anyway, only other thing may be shipping.    I can make the panels for you for nothing but not sure where you live or what shipping would cost.  I am just outside of Chicago.
Color is not an issue but I need 3mm thick to be even with rest (and I have to bend it)
Many Thanks anyway.
PS Iwould pay the costs of course
Shipping to NY12953
Can Poly be heat bent? I suppose yes.
yes, that is what I used for around the top of the radio Pedestal.   Heated with a torch and it bent easily.   Holds it shape perfectly afterward.
Only probably is that the paint might get ruined if it was painted first.    May be better to be bent first then painted.   Your lenth may have to be adusted slightly for the bend also.
The length is already calculated for the bend.
I do not know anything about poly.
Painted acrylic panels bent quite well with a heat gun
see: http://www.cockpitbuilders.com/community/index.php?topic=640.0
well my guess is this would be fine.  The paint I use is a PPG auto interior paint that is sprayed on after using plastic adhesion promoter.   I will take a heat gun to a test peice and see if it works.
Jack, if it were my project, I would make those individual pieces instead of a whole plate. Working a piece at a time it would be much easier to bend them with heat, and you can attach the rubber dustshields individually afterwards.
Just another idea I used.
Hi Mike
Had that thought, ... it means more screw heads and less clean design.
But it remains a very valid option.
Thank you for the tip.
I know yours is a hybrid design, but that's just what Boeing did with the earlier throttles. There are four countersunk screws holding each of the plates to the bulkheads.
I rather like it myself, but I like that old tech stuff.
Well I will test the paint tonight for heat resistance and let you know how it works Jack and will confirm before cutting that you still want to go that route.   I probably will have to do this over next weekend if that is ok as I will be out of town on business Wed. and Thursday but happy to help out if I can.
Well the heat from a heat gun held at around 1/2" for a good minute did not effect the paint at all.   This paint I use is really the stuff....
That said, the heat gun didnt seem like it had enough heat to allow the poly to break down and go limp for reforming.   When I did the piece for my pedestal I actually used a propane torch to heat up rapidly then bent.  That obviously would not be good on your actual throttle quad but could be done fine over a form.
The other thing about the poly is at 3mm it is very bendable without even heating.  You could literally bend it over your top probabaly fine but would have to hold it down somehow at each end.
Jack,
Just double checking that the bottom part is 3mm?
Make it 5mm (3 is too slim probably)
I will modify the idle stop position of my levers.
I tried to have maximum travel.
The second small panel will go over the back open end. The fact that it is removable allows sliding in /removing the main panel without disassembling the power levers.
If you do not mind trying It should be fine.
The 5mm end makes it vulnerable during shipping, has to be sandwiched between someting rigid.
No rush whatsoever , of course.
Thanks a ton.
JP
ok
I will make it 5mm.   No problem.  Have plenty of poly and this is a quick cut for the cnc.    I have some of my panels for my MIP to paint this weekend so will paint these at same time.
super nice
Thanks Scott.
Hey Scott,  if you get a chance to take pictures of the various steps, I would love to see how you do this..
Well, I got them cut.  I did one out of 3mm poly and also because I had recently got an aluminum cutting endmill and some 2.25 mm thick aluminum I decided to give that a go as well.   They both turned out nice.   The endmill I got for aluminum cut it like butter.   Very cool.    Anyway, I did a little video of the cnc process from artwork to cam to the cnc but wont have time to put it together and up until the weekend.    Jack, here is a little peak at the cover plates.    I will paint when I get back this weekend and they can be out the door to you on Monday (I will send both and that way you can try either).   The aluminum is pretty stiff stuff but I am sure it would be easy to bend on the curve you have and would definitely hold shape.
Wow Scott.. Very very nice!
Fantastic..  Looks great guys..  Awesome.
Flabbergasting...( if that word exists and is correctly spelled)
Wahoooooooo!
GOT THEM....
They fit perfect..I think I will use the aluminum one..
Will report
Thanks a ton Scott!!!
Super work and nice help!
Great!
Glad they fit.   Yeah, my choice would have been the aluminum one also.  Sorry I didnt have the exact thickness but it should be close and easier to form.
Glad to help.  That is what this hobby is all about.
Thickness no prob...will now have to curve it gently...
