June 20, 2024, 09:48:07 PM
157 Guests, 0 Users
  • Online today: 123
Guests: 157
Total: 157
B737 Rudder adjusting crank unit
Started by MjTom, June 18, 2017, 11:22:17 PM
MjTom
Hello,
Mostly I have no original pictures, now I have two different.
Once directly under the lower light panel....
....the other directly above the metal cladding and a piece below the light panel.
Which is from the B738-NG ?
If somebody have a few pictures from the NG adjusting unit or measures, I would be very grateful.
so long, Thomas
Karl737
Hi Thomas,
The top one is from a classic and the bottom from an NG.
Will take some pics for you tomorrow...
Karl
Gallie
It looks like the top is a real crank + CB panel mounted to a replica bracket and mip frame.
Both classic and NG cranks are located at the exact same position. The lower subpanel frame on a classic and NG have the same hights.
The classic crank brackets are rivited to the mip frame where the NG crank is bolted.
The mounting bracket is the only main difference in apearance.
I can send you some pictures of my classic crank + bracket mounted to my replica NG mip frame, let me know if you need them.
Michael
rudder crank with cables ... may i suggest an alternative    give it ekectric motor   might be easier
Cables ?
Linear motion is best obtained with this type of gearing
Can be manual, with a crank, or electrical with a motor
MjTom
The manual variant, this I will implement:
willow
Hello Thomas
Karl is correct.  The upper image is from 500 series.  I should have mentioned this in my article - my apologies.
I have since updated the article on the website to reflect this.    Cheers,   WilloW
WilloW  (YMHB)
www.Flaps2Approach.com
on 74 its cables and oddly enough quite effective ????
My units are actually a switch as I motorized my rudder adjustment like the 777 has!
http://www.aerosimsolutions.com.au/products/b737-rudder-adjusting-crank/
You can use my pictures for scaling, they are the right size!
Cheers Gwyn
I got a set of Gwyns' Aerosim Solutions cranks in my cockpit. I added a set of real circuit breakers in both and they look just like the real thing....thanx Gwyn!
Frank
Buster99
#10
Hi there,
I do not have the cranks but have a picture of the attachment under the MIP that may be of help.
(737NG)
Marc
737NGer
Is that a real NG MIP frame? Out of its shell? Is it for sale? I really need one of these.
Buster99
#12
Hi there,
Yes, real 737NG MIP out of the shell but pictures are from some time ago, no shell or MIP for sale  :(
Here is what the crank looks like.
Karl737
Hi guys,
Some pics from me, too.
Hope these are of some use.
Karl
Buster99
Wow, super pictures!
Thanks a lot,
Marc
