June 26, 2024, 02:58:52 AM
60 Guests, 0 Users
  • Total Topics: 7,853
  • Online today: 107
  • Online ever: 831
  • (May 03, 2024, 12:39:25 PM)
Guests: 60
Total: 60
COUNTDOWN TO WF2022
Switch Wiring
Started by props, April 17, 2016, 02:20:34 PM
props
Hello fellow simmers, I working with the Leobodnar Buo836x card and I wondering would it be possible to wire a spst switch that illuminates to the card.
See that a spst common switch works,just wondering how?
        Thanxs again
If you mean you want to light a led when switch is closed. Then connect
a 470 ohm resistor in series with a led  from 5v to Buo386x input. Anode
to 5v.
Les
props
Hey Les thanks for the respond, a three prong switch one to power, one to ground and one with the resister to the card ??
this is my first time :huh:
        Props
No,
Centre of your switch to gnd. Either end to input of card. Cathode of Led
to input in series with resistor to 5v. Switch closes signal sent via card
to FS and led turns on.
See here
http://www.leobodnar.com/files/basicLEDswitch.pdf
les
props
Hey that works pretty good thank you, iwik
        props
