June 24, 2024, 04:31:47 AM
175 Guests, 0 Users
  • Online today: 171
Guests: 175
Total: 175
B737: measures from oxygenmask etc.
Started by MjTom, November 04, 2015, 10:06:27 AM
MjTom
Hello,
I´m currently working on the sidewalls but something does go wrong.
I´m not able to transfer measures from cockpit-pictures to my homecockpit.
Cupholder, oxygenmask etc. are incorrectly positioned.
Perhabs somebody will be so kindly, to have a look at my measures.
.....where is bug?
thank´s and so long, Thomas
Buster99
Hello Thomas,
One thing is the Oxygen Mask boxes, dimensions of the real ones is 147x114mm (top panel).
The other dimensions I do not know for certain.
HTH,
Marc
MjTom
Hi Marc...
.....that´s a good first indication to clarify some of the inconsistencies!
I´ll going to test it immediately.
thanks
Buster99
Hello Thomas,
I hope that you get it figured out  :)
In case you need other dimensions for the oxygen mask boxes, just let me know.
Marc
andthiel
Thomas,
the best sidewall dimensions can be found here:
http://www.fagerjord.org/images/cockpit/boeing_737_sidewall_construction.pdf
Andreas
Best, Andreas
MjTom
Hi, Andreas
That was the plan, I build the sidewalls. I was realy happy, to find this side.
Slowly, it comes light in the dark.
- the measures from cupholder must be bigger than 150mmx155mm, perhabs 185mm x 185mm.
- document pocket might be 160mm x 50mm.
- the post might be 80mm x 50mm
Now it looks more realistic, the hope is increasing.
I will show you the result after painting....so long, Thomas
andthiel
In my setup, the cupholder measures 150 x 150 mm.
Andreas
Best, Andreas
MjTom
#7
That´s exactly one of my problems.
I have a (bad) picture from a B738 and when the measures of cupholder are 150mm x 150mm
the measures from the sidepanel are wrong.
Can you please check measure a and b?
another picture from the PMDG:
andthiel
Forget the PMDG for measurements!!!
Andreas
Best, Andreas
andthiel
Thomas,
the measures for both a and b are 170 mm.
Do you come to Lelystad this weekend for the FSWeekend?
Andreas
Best, Andreas
MjTom
#10
Quote from: andthiel on November 05, 2015, 04:09:36 AM
Thomas,
ok, some measures from fagerjord-plans semms different.
170mm x 170mm makes sense and looks good.
my sidewalls must move ~6cm forward. Than, the rear sidewall looks also better.
Thomas,
.....no way this time.
edit: so it will look after modifikation:
Have somebody the measures from the document-pocket ?
I need it for better positioning the post.
so long, Thomas
