June 26, 2024, 12:13:15 AM
104 Guests, 0 Users
  • Online today: 97
Guests: 104
Total: 104
scojj
Navdatas are up to date from the latest serial from the navigraph site.
Well I am not sure about nav data collected from anywhere except but the pm site. So I can't help you with that part.
Do you run the CDU and PFF/ND on the same machine?
Check your cdu.ini file and see if FLUSH=Off. Also, are you using a second FO CDU and did purchase/have the RCDU (FO Side) of the pm software?
scojj
The CDU and PFD/ND run on the same machine, but did for years without this problem to occur.
I have the complete PM suite but don't run the RCDU : this will be for later.
I will chek the FLUSH=OFF, I think it's ON
Thank you Trevor and blueskydriver.
scojj
Hi gents,
I checked this evening the FLUSH options that were both set to ON and put them to OFF.
Then made a flight from EBBR to LIRN (nice landscape with the Vesuvius).
The same occured.
Waypoints erased soon after takeoff.
The only remaining waypoint was the arrival runway...
No answer from PM.
Hi scott the flush option to my knowledge is when you land does it clear the CDU.
Post here your pm file check results please
I am hoping to have my sim back up and running tonight. So in the next say or so I may have some input on this. I too am using PM.
Don't think you should do an upgrade, If I were you I would copy your Keys, Completely uninstall all of the PM Software and your Nav Data.  Then go and delete all left over traces of the PM Software. Ini and Config files as well. Reboot and even do a registry clean of anything PM
Do a "Complete Install" (IN A NEW DIRECTORY) all of your software again.  Do not install NAV Data and see what happens.
I bet that will solve your issue if you are sure UAC is off and all your directories are Writable.
Just to confirm I hope you are using WideClient and not some simconnect crap.
scojj
Hi Trevor,
I know the flush option is for celaning the route data once landed but that was one suggestion and I wanted to try it.
I will post the pmfilecheck here down.
I use WideClient, not simconnect.
I will try your suggestion of the complete clean uninstallation and reinstallation, but I already tried it. (without erasing in the registry).
I will also try to install the latest navdata from PM and not the latest one from Navigraph.
JJ Scohy
Here is now the pmfilcheck :
pmFileCheck Build  82
Opening Connections
Windows 7 Ultimate
Windows Indexing Service is OFF (good)
User Account Control is OFF (good)
Local Path: C:\Users\GLASSC~1\AppData\Local\Temp\Rar$EXa0.186
Checking Computer and User Name
Local Computer Name: GLASS-PC
Local User Name: Glass cockpit
FSUIPC/WideFS found!
FSUIPC Check  1229127680
FSUIPC Check 0x49430000
FSUIPC Version 4.943
Lat/Lon/Alt/Hdg
505444N 0043008E -223 246
FS Version: Prepar3d
WideServer Version 7.943
WideClient Version 6.992
Flight Simulator Running
Testing FS Framerate and Data Rate for 10 seconds
FS Framerate Avg / Min / Max: 57.9 / 41.6 / 59.4
Data Read Rate in ms Avg / Min / Max: 32.9 / 10 / 57
Data Rate: 303 Ticks  30.3 data sets / sec
Read Attempts: 884 with  88.4 data sets / sec
Read Same Value: 581
OK   - GC Detected
GC Build  506
OK   - FMC Detected (CDU or MCDU)
FMC Build  506
OK   - A/P Detected (MCP or FCU)
A/P Build  506
Local Directory is C:\Users\GLASSC~1\AppData\Local\Temp\Rar$EXa0.186
Local DLL Files Found:
   pm.dll dated: 5/10/2015 16:22:33
Checking FS Path
OK   - Reported FS Path \\FS-PC\Program Files (x86)\Lockheed Martin\Prepar3D v2\
Trying to access FS Path
FAIL - Read access to FS Path
OK   - Read/Write access to FS Path
Wide Server reports:
19484 Connected to computer "GLASS-PC" running WideClient version 6.992 (skt=11244) TCP
Looking for NETDIR from CDU
Reported NetDir is: \\glass-pc\netdir\
Checking PMNETDIR Path (FMC Generated Path)
7 File(s) found in NetDir, last date is 5/10/2015 16:20:58
cdutype.bin
cdutype.txt
pfd.pln
route.bin
routeout.xml
routeoutb.xml
thrust.bin
Checking FSPLANS Path (To Load/Save FS Flightplans)
OK   - Read/Write access to FSPLANS Shared Folder
5 File(s) found in FSPLANS, last date is 4/10/2015 22:27:14
List of active processes:
[System Process]
System
smss.exe
avgrsa.exe
avgcsrva.exe
csrss.exe
wininit.exe
csrss.exe
services.exe
lsass.exe
lsm.exe
winlogon.exe
svchost.exe
WtuSystemSupport.exe
nvvsvc.exe
nvSCPAPISvr.exe
svchost.exe
svchost.exe
svchost.exe
svchost.exe
audiodg.exe
svchost.exe
nvxdsync.exe
nvvsvc.exe
svchost.exe
vsmon.exe
ISWSVC.exe
spoolsv.exe
svchost.exe
armsvc.exe
avgidsagent.exe
avgwdsvc.exe
ForceField.exe
taskhost.exe
dwm.exe
explorer.exe
SetPoint.exe
wmdcBase.exe
svchost.exe
svchost.exe
ToolbarUpdater.exe
loggingserver.exe
conhost.exe
WideClient.exe
pfd.exe
MCP.exe
svchost.exe
VolPanlu.exe
avgnsa.exe
AMBDEF.EXE
zatray.exe
avgui.exe
KHALMNPR.exe
svchost.exe
avgemca.exe
FDS-CDU.exe
cdu.exe
sa_wxr.exe
AdobeARM.exe
vprot.exe
SearchIndexer.exe
wmpnetwk.exe
svchost.exe
WmiPrvSE.exe
ctfmon.exe
avgcefrend.exe
iexplore.exe
iexplore.exe
iexplore.exe
sppsvc.exe
WmiPrvSE.exe
WinRAR.exe
pmFileCheck.exe
avgmfapx.exe
SearchProtocolHost.exe
SearchFilterHost.exe
Closing Everything
5/10/2015 16:22:59
Things To Do:
* Limit FS Framerate to allow more network throughput (FPS is > 40)
If you wish to, please check www.projectmagenta.com/notams.html
scojj
Quote from: Bob Reed on October 05, 2015, 03:50:10 AM
Thank you Bob,
Curious to read your input.
This is interesting from Above.....
****  Trying to access FS Path ****
Also, I am not super happy about the local folder having "TEMP" in it.  Thats also not a good idea.  We all know the Temp folder gets written to and erased lots..
I will also note that Mentioned in the PM Docs....  FS Folder being inside "PROGRAM FILES" Is not recommended..  as no matter what authentication level you have, Generally the Program files folder is OFF Limits to Network users.
Be cautious here.
I would need to check mine, but I am pretty sure these should be the same version?  Can anyone else confirm this>?
scojj
Hi Trevor,
The TEMP folder is the folder from which pmfilecheck was working.
The READ access fail is strange on FS path, as there was no READ/WRITE access fail (just one line after).
I have P3D in the Program file folder but not in C:\.
This was long before I had the problem so I'm not sure this is the cause.
Roger that..  Just wanted to point out some possible causes.
I know I keep PM in the root..  I also Keep FS in the ROOT as well.  Obviously don;t change it now, though or you will really break things..  Just something I threw out there.
scojj
I know you were searching possibe causes. Thanks !
The READ access fail is anyway strange.
I would be willing to bet, that it is plausible that if it fails in file check (Even though it passes the next ones) that may be the cause of your cdu wiping.  perhaps on the first attempt when it fails that's where it clears your route.
If I get a chance tonight, I will run my file check and report back to you if mine ever fails.  (I don;t think it does) But I will let you know the next time I try.
Oh One other thing..  Disable AVG LOL  That could also be a pain in the ass.
scojj
I'm curious to see your pmfilecheck report.
I have AVG and Zonealarm running in background, I know they can be serious problems.
They didn't for years but a simple update can be killing.
I will also try without them running in background.
About the READ access fail I will have to search for the folders authorizations in Windows 10.
I recently updated the main FS PC to this but that was after the erasing problem had occured.
Ok scojj, I am up and running once more. I am not using the latest builds but I can tell you I am not experiencing the problem you are having. I have about 8 flights in already with none of those kind of issues.
scojj
#45
Hello dear friends ,
It seems that I've found the solution to the problem.
The firts flight is at the moment in the descent phase after the correction, and my waypoints are still alive...
The concern was about a major update of the PM glass cockpit software.
This newer version installed in a different folder from the older one that was named "PFD", in a new folder named "GC", with newer config files.
In the .ini file, the aircraft type has to be set to "CDU" if one runs the PM CDU software besides the glass cockpit software.
And with a new installation it was not the case...
After correction of this line in the .ini file, it seems to be obviously the solution, at least for this first flight .
In french there is a sentence that says "the devil lies in the details"...
Best regards and thanks to you all for your help.
Excellent to hear. And now we have a record of this for the next time. Awesome job and thank you for reporting this back to us. Happy flying.
That's awesome, way too keep digging to find the problem! Thank you for posting... Can you post the PM update number that caused this please?
Best Regards,
scojj
Keeping the post up to date was of course a thing to do since you were all present to listen, care and help and I thank you for that.
The precise version is difficult to fix because the last official installer at PM site is from 2014-08-27 and there are multiples updates after this date.
Also the version n° of the last complete setup is 5.06 and the last update is 5.12.
To be complete and honest I run PM softwares from years and it's possible that more than a few years ago the installation folder has changed : I had reinstalled the PFD software recently so that's the source of the problem.
The conclusion is : if you have to reinstall one or more software from PM, be sure to read again the user's manual to complete all steps of the configuration in the .ini files, to be sure they comply with your setup.
scojj
Here we go again...:(
The previous flight was normal but yesterday I made a second flight during which the same problem occured again.
I didn't change anything in the programs setup...
As Shakespeare wrote, "There is something rotten..." in my PC.
I think the only solution will be a clean reinstallation of Windows 7 and the PM suite from 0.
