June 22, 2024, 07:07:15 PM
205 Guests, 0 Users
  • Online today: 324
Guests: 205
Total: 205
Arduino controlled Real HSI
Started by 727737Nut, February 17, 2015, 06:29:38 PM
This Real 737 HSI is controlled by a Teensy 3.1 using Arduino code. All but the compass card as couldn't figure out the 'home' stepper programming in Arduino. :(
http://youtu.be/EGO46euosyE
Hey Rob.
I read somewhere someone was doing that. They used a photocell through a notch on the card. The card on power up rotates to the known position where the photocell catches it and resets everything. If I am not mistaken every time the card rolls past 000 it resets the position.
Just a thought.
EAL727Captain
Impressive.
Care to share your Arduino code?
rprather
Rob, nice work! Did you install stepper motors or are you communicating via the ARINC pins?
Quote from: rprather on March 03, 2015, 01:26:31 PM
Thanks Robert,
I am using one stepper turning a remote mounted synchro to drive the Azimuth card. The Course and Heading bug are driven from the same signal fed to the AP panel which then sends it out to the HSI via internal synchros   Using most of the original internals so far.  All my stuff is to old for the ARINC 429 data.  The digital DME readouts use I believe ARINC 561 but I will use an Arduino for that.
