July 06, 2024, 08:53:54 PM
26 Guests, 0 Users
  • Total Topics: 7,854
  • Online today: 62
Guests: 26
Total: 26
Cheap map lights
Started by Aerosim Solutions, September 30, 2013, 06:57:04 PM
Hi all,
I have just made a couple of map lights to go with my newly acquired eyebrow trims. I bought a pair of $9 LED flashlights and basically cut them in half! I made a gimbal bracket so they can be aimed anywhere when they are mounted. I soldered wires to the battery contact tabs and fitted a simple connector block for the 3Vdc power supply. The torch button still works and they look close enough, a cheap solution!
[smg id=996]
[smg id=997]
Cheers Gwyn
Karl737
Brilliant!! (pun intended) ;D
Karl
glooker
Gwyn,
That is a great piece of work.  Simple and elegant.  You have Inspired me to make my own.
Greg
Quote from: glooker on September 30, 2013, 10:48:57 PM
Gwyn,
Greg
They are Arlec torches Greg, I got them from Bunnings!
Cheers Gwyn
Good idea Gwyn
I used some also for the side map. ($3)
I feed them 5v from the OVH PSU with a resistor.
Nice work on the Map Lights Gwyn!  I always am inspired by your innovation.
Have you done anything similar for the light on the upper part of the Fowward Overhead, which illuminates the Pedastal area?
Quote from: sagrada737 on October 01, 2013, 06:29:01 AM
Hi Mike, I haven't got a roof structure yet!!
Cheers Gwyn
wildcat02
For the OVH I used the head of a small desk light.
http://www.flightdeck737.be/hardware/fwd-aft-overhead/samenstelling-en-onderdelen/
I've built the' map lights' with parts of plumbing, a lamp holder and a LED lamp.
http://www.flightdeck737.be/pc/electronics-2/map-lights/
To give an another idea ... ;)
Clement
