July 02, 2024, 08:09:12 AM
27 Guests, 0 Users
  • Total Topics: 7,854
  • Online today: 30
  • Online ever: 831
  • (May 03, 2024, 12:39:25 PM)
Guests: 27
Total: 27
COUNTDOWN TO WF2022
FSC Motorised Throttle
Started by markfire, June 11, 2013, 10:40:19 PM
markfire
Hi all
Prosim & FSC Motorised TQ This may ve been discussed before, but a lot of posts deal with the non motorised version.Using the prosim built in driver, the throttles calibrate and work well, the flaps work well although seem a little slow!
The Speed brake calibrates as it should in the software, but will not arm correctly and deploy. It also doesn't return to down as it should when power is applied. I've noticed that when landing and its in the arm position, on touchdown the lever goes down automatically rather than up as required. I also noticed that when putting the spoiler into the arm option the speed brake extended light comes on briefly then the speed brake armed light, so I guess there lies the problem.One other thing (minor) is when prosim starts the backlighting goes on the goes back off again? I think the TQ is 70% there.Has there been a fix i may have missed or is there a fix being worked on?
A custom driver was created for the IFly 737 and that works all the functions correctly ( better than than the FSC driver) so I guess it can be done!Many thanks in advance.Mark
rhysb
Mark,
2 things, firstly I'm in your area (tomorrow) if your about so I can have a look at it if needed,
Secondly have you checked through the prosim forum? I know there was a couple of posts on the fsx throttle there recently
Rhys b
markfire
Hi mate
Yes i'll be here. you got my address and mob no.?
Morning is best.
Yes I've checked the forum and doesn't seem to point to any specific areas where I may need to check. I'll carry on playing and maybe two heads tomorrow will suss it out : )
regards
Mark
