June 26, 2024, 12:03:06 AM
77 Guests, 0 Users
  • Online today: 111
Guests: 77
Total: 77
B737 Startswitches
Started by archen, February 23, 2013, 11:07:59 AM
archen
#75
Hey guys!
To celebrate the purchase of a new machine to my workshop I'll be offering free shipping worldwide this week starting now, ending on Sunday.
The new machine is a EMCO cnc lathe. I've been missing a lathe for a while and this machine is very welcome. It's a CNC lathe with a six tool automatic tool changer. It will definitely open up for new products and I'm already working on a new project that will take benefit of the new machine.
Thanks to all! It's been great fun to get to know so many talented builders.
Edit: added a picture of the new machine
Anders
Skickat från min GT-I9505 via Tapatalk 2
Anders Simparts
http://www.anderssimparts.com
Congrats on the new machine!
Looking forward to more of your great ideas!
Congratulations on the new baby, its a good feeling when you upgrade something, i know too well.
May send some work your way as i was thinking about a CNC lathe also
Phil
archen
#78
Thanks guys! It feels great.. I hope I will have a lot of joy with the machine both in my company but also in my own sim build.
Made some Threading and cuts last weekend. Still only in testing purposes but I'm very impressed with the machine and what you are able to achieve with the right machines.
Phil just send me an email or PM if you wanna get in touch.
Anders
Anders Simparts
Congratulations Archen on a new machine!
And I just placed the order for start switches - thank you for your generous offer!
archen
Thank you very much :-)
Got the order. Thanks!! Your switches is already packed and ready for despatch. Will goto the postal office tomorrow and drop it off.
/Anders
Anders Simparts
Ridgenj
Anders, congratulations for your new toy.
I have have my starter switches but comparing both products yours looks pretty well finished.
If I would take a decision today, I will get yours without doubt. I like them so much that I am debating if I should just get them.
I was looking at your store and I can't figure out where the switch for the MIP will fit.
Luis
archen
Thanks Luis! :-)
The switches you are reffering to is the N1 / SPD Reference set switches which can be found on the autobrakepanel. These switches is special. You select the desired value you want to change with the bigger (inner knob) and then with the outer smaller knob you change the value by holding it to the left to decrease the value and to the right to increase the value.
Each direction have two positions. Turn it a little and the value decreases/increases  by 1. Turn it to it's limit (about 90 degrees) and you increase/decrease by 10.
These switches is not very common because they are barely never used in the real plane except from dual fmc failure. I made them because I try to make everything as real as possible within a reasonable budget. The real switches is very rare and I haven't seen anyone yet. I had the opportunity to feel them in the real plane and tried to make them as real as possible. Most builders don't bother about these switches because of their low usage so they haven't sold nearly as good as the starters but that was expected. Thought I do add them to the store so they are available to the users who wants everything as real as possible. Because they are quite rare I don't stock them and they requires 7-10 days to manufacture.
You will need knobs for them as well. They are built to fit the knobs from www.knobs.se but I guess most knobs would do it if you find any. The inner knob is a normal rotary shaft and the smaller knob is a 3mm shaft.
Anders
Anders Simparts
Ridgenj
#83
Thanks Anders for educating me about it.
I have a Sismo module that uses dual concentrics but apparently they don't fit my still to arrive FDS MIP.
With exception of wipers and toilets I try  to be also as accurate as possible.
Let me know if they will fit the FDS MIP and panel.
Luis
archen
Hey Luis,
I haven't had the opportunity to test them on FDS MIP but I don't think it should be any problem. I have Simworld MIP and they fit without problem.
Take a look at my B737 N1/SPD REF thread: http://www.cockpitbuilders.com/community/index.php?topic=3280.0
You have all the measures in that thread to check if it will fit. I recommend you to cut a circle with a diameter of 40mm and hold on the back of the panel to see if it clears everything.
Anders
Anders Simparts
archen
I should add that you need prosim737 to be able to use them the way they are supposed to be used. If you are good with sioc I guess you can get it work with anything but I'm not good with sioc so I can't say it work!
I still haven't  had the opportunity to try it out with sim avionics.
Anders
Anders Simparts
I have tested with Sim-Avionics, FDS Relay card, and Interfacit and they work beautifully.
archen
Hey Scott,
We got slightly off topic so I was reffering to the compatibility between  N1/SPD Ref set and sim-avionics, but thanks for confirming that the starters work with sim-a, good to know if someone asks.
Anders
Anders Simparts
archen
Attached a simplyfied wiring diagram made in paint  :o
I'm looking into a more proffesional diagram.
Anders
Anders Simparts
Thank you Anders - I just received the switches.
Excellent quality!
archen
Thanks Nick!! Glad they arrived safe.
Let me know if you have any questions.
Anders
Anders Simparts
Hello Anders,
Add me to the list of happy users of your nicely built Start Switches.  I finally have them installed in my FDS Overhead kit, and they work as advertised.  Thanks again for a great product - it has helped to add another level of realism to my Sim Project.
archen
Thanks Mike! I appreciate your comment.  :)
/Anders
Anders Simparts
archen
Anyone with OC overhead that can tell me the location of the lockinghole in relation to rotary mountinghole? Is it twelve o clock?
Thanks for your help!
Anders
Anders Simparts
archen
Hello guys,
Just wanted to share a video with you, demonstrating the new machine in production. First parts that is being manufactured in the the CNC-lathe.
Enjoy:
Archen Simparts - Making of Engine starters #1
/Anders
Anders Simparts
Anders,
I have an OC overhead.  What exactly do you need?
markfire
Nice piece of kit you've got there Anders.
Can it make a 737ng throttle quad?   : )
archen
Quote from: fsaviator on September 26, 2013, 01:14:20 PM
Anders,
I'm wondering about the pinlocation. The little hole that locks the rotaryswitch from rotating. Usually the pin is located at 6 o clock but I've seen some vendors have it at 12 o clock.
Quote from: markfire on September 26, 2013, 01:23:04 PM
Thanks Mark. throttle quad is a little to complex for me at the moment :-) Wish I could make one though.
/Anders
Anders Simparts
Quote from: archen on September 28, 2013, 09:56:57 AM
Anders,
Ahhh.  Now I'm tracking.  I need to pop off one of the panels anyway, so I guess now is a good a times as any.  Let me see...
It appears to be at the 12 o'clock on this panel.  This is the Version 2 fully assembled overhead.
archen
Anders Simparts
