June 22, 2024, 07:41:02 PM
207 Guests, 0 Users
  • Online today: 324
Guests: 207
Total: 207
Citation Mustang Builder
Started by 2CharlieMike, June 11, 2011, 04:36:42 AM
hexpope
#25
Any progress on the build? You can get everything working perfectly with switches etc using LINDA LUA scripts. Not only that but theres a file is in the FSUIPC installation folder for that extact plane, so all the work is done for you. All you need to do, select your button, use the drop down menu and assign it.
cityalex
#26
I'm working on Cessna Mustang cockpit, right now on G1000 bezel.  It will be greate if someone will be able to share Mustang dimensions, or at least GCU 475 dimensions.
Just sent you a PM as I built a Mustang sim.   Also you might want to ck out this site as he sells Mustang parts. http://www.ruscool.co.nz/
cityalex
I've made some calculations on pictures.  Looks like GCU 475 size is about 130x100 mm.  If somebody knows exact size, please confirm or rebut.
Jmg225
I have all the avionics including autopilot, keypad, complete lower switch panel, MFD customized to real dimensions, PFD, standby instruments.  They all can interface with flight1techs Mustang version of their G1000 simulator. The autopilot and keypad are usb,  the other avionics wire to two circuit boards via Ethernet cables (included).  The circuit boards are usb connected to the pc and is powered by a computer power supply which is also included.  It is everything you would need to build a Citation Mustang cockpit except the shell and whatever type of viewing system you're  going to use for the outside.  It is over $6500 of simulated avionics.  I am selling everything for $2500 or best offer.  They are all in excellent condition.  If you're interested email me  jgaffney225@gmail.com
