June 22, 2024, 06:20:46 PM
287 Guests, 0 Users
  • Online today: 324
Guests: 287
Total: 287
Need some help on this one.
Started by 727737Nut, November 04, 2010, 12:55:50 PM
I'm hooking up my real 737 TQ and I have a clutch mechanism like Jack has on his throttle. I am using 1/16" steel cable attached to a short section of chain.  I had installed a pot and small nylon pully on the pot but i am having slippage issues on the cable to pulley area.  I don't want to go with anymore tension so the only idea i have is some kind of rubber coated or more grippier surface. Any other ideas.  A string pot would be best but i can't afford those now so i have to figure out a way to use regular 3 turn pots that i have on hand.
Thanks!!
matta757
hey,
do you have a pic of the described area? i'd have an easier time given a suggestion if i had the visual assistance!
matt
fordgt40
Try using a ribbed pulley belt and matching pulley - all available quite cheaply from here
http://www.motionco.co.uk/timing-belts-timing-belts-c-25_38_27.html
I am using these products for driving my throttle levers and found this outfit to be quite responsive
Here are a couple of pics. I can't change the set-up i have so i must find something to work with the cable and or chain.
